2009 1500 Airbag Suspension Options
Old Oct 4, 2011 | 04:02 PM
CrawfishStu's Avatar
CrawfishStu
Default 2009 1500 Airbag Suspension Options
I use my truck like a truck. Lots of towing. Lots of bed loading. With 85k on it, my rear springs are just sagging away.
I have airlift bags on the rear currently. Rancho 9000x shocks. Daystar lift level kit.
I'm looking to move towards a full on airbag replacement suspension. I'm not finding much.
This one seems nice and has the option of running it like my current setup or putting in a high dollar onboard air setup with self leveling:
http://www.ridetech.com/store/suspen...ar-system.html
But was looking to see if anyone has any other leads.
Old Oct 4, 2011 | 04:12 PM
jayman84's Avatar
jayman84
Kelderman has a full kit that replaces the coils and you can even get a leveling valve
Old Oct 4, 2011 | 04:24 PM
CrawfishStu
I had looked at them but didn't see any info on fitting a 2009 1500.
Old Mar 6, 2012 | 02:39 AM
InterpunX's Avatar
InterpunX
I'm starting to think about doing something like this also but there's not much out there. Like you said there's bags from ridetech http://www.ridetech.com/store/trucks...hash=V302.V328
or there's a new firestone product which is very similar to ridetech and also for top dollar for the hole kit. http://www.allpar.com/forums/index.p...-for-ram-1500/
And the Kelderman kit http://kelderman.com/node/220
I think ridetech is the better option because like you I have airlift bags and i could probably use the same hoses and onboard compressor with the ridetech bags. The only issue i have is if it would fit with my Procomp lift and choosing the appropriate shock.
Old Mar 19, 2012 | 07:18 PM
CrawfishStu
Hellwig also makes a nice kit.
How much lift are you running? I'm running a lift level kit and RideTech told me that their bags would run just fine at 1.5 to 2 over factory ride height.
Old Mar 19, 2012 | 08:17 PM
72combo's Avatar
72combo
Do these 4 wheel kits work on 4wd trucks?
Old Mar 22, 2012 | 03:07 PM
CrawfishStu
I don't know but I'll tell you that their customer service and tech department are really nice. Instructions lack a little, but they make up for it.
I put the kit on and had some issues. User error. Whatever I did caused the sleeves to not want to fold back in like they should. 30 feet after I rolled out the bags spit out and took out a brake hose. They were a pain to get back in place but I finally got them squared away with some advice from them. I then hooked my trailer to the truck and was instapissedoff. According to other sources, the max psi should be 110. At 110 with my trailer on there I was on the bump stops and the trailer jack leg was not off of the ground. I called ridetech up and asked what the safe operating pressures were because my trailer was dragging at 110. They said they burst test the bags at well over 400psi. 125-130 had me sitting just right. He was a skeptical at first "Why....How much are you trying to put in them?" But quickly came around after I told him what I needed to get it up to ride height with my trailer in tow. Apparently some guys really push the limits with nitrogen in some of their bags.
Old Mar 25, 2012 | 09:29 PM
CrawfishStu
I'm pretty dissappointed in the RideTech kit at this point. I hooked the trailer up to head out for a day of wheeling. Aired the bags up. Pulled off and they unseated again. Reseated them and used a little less air. Pulled off and they unseated again.
Cancelled my wheeling trip.
I'm looking at the other kits available.
Old Mar 26, 2012 | 12:21 AM
InterpunX's Avatar
InterpunX
Interesting, thanks for the heads up
Old Mar 26, 2012 | 03:50 PM
72combo's Avatar
72combo
Check out that show with Stacey's Davids Gearz he is up one of those Dodge Express trucks with a HEMI he put an air suspension front and rear. Didn't look too hard but he did have to cut some metal in the front which I would be nervous about doing.
