hid ballast location
I'm installing hids in my 2010 dodge diesel laramie, but i'm not really able to find a good spot to put the ballasts. i'm running hid hi and lows with a relay harness. i got everything working good with no codes or warning lights but dont know where to put the ballasts.. anyone have experience with this?
thanks
thanks
thanks
thanks
Here's some pictures you can see...Sorry the picture quality sucks, these are the only two that I snapped using the cell camera....Also both pics were taken on passenger side, same goes for driver side....Hope this helps a little bit let us know what you end up doing.
IMAG0475 by Mikeyyy816, on Flickr
IMAG0474 by Mikeyyy816, on Flickr
thanks, i'll try that. what did you connect you wiring harness to send a signal. i tapped mine to the marker light signal, seems to work alright so far. also did you have to use the capacitor? i hooked mine up last night just to test everything out and never got and warning lights. i just need to pick up another harness to run my hi beams..
are you asking what I tapped into for power? If so I just went to the positive block in the fuse box... and yea I used a capacitor, but I am also using a RAM specific harness from the place I ordered my HID's from. Also I switched from Dual Headlights to Quads..
Here's a pic of where I got my power source (if that's what you were asking)
IMAG0471 by Mikeyyy816, on Flickr
The harness I use...
IMAG0281 by Mikeyyy816, on Flickr
funny, I did not have to run back for a power source...im pulling right from the factory plug...
