Front Diff
Old Jul 19, 2012 | 08:43 PM
TheRiz's Avatar
TheRiz
Default Front Diff
Need to replace front diff lube. How much do I need? 09 Ram.
Old Jul 19, 2012 | 09:06 PM
oldjeep's Avatar
oldjeep
56 ounces of GL-5 SAE 75W-90 (MS-9763) or equivalent
Old Jul 19, 2012 | 11:23 PM
Mikeyyy816's Avatar
Mikeyyy816
OldJeep 56 oz is almost 2qts...When I did my front diff two months(ish) ago I had to add just over 2qts to my diff, to be just under the fill hole.
Old Jul 20, 2012 | 07:24 AM
oldjeep's Avatar
oldjeep
I'm just going by what the 2009 factory service manual says
Old Jul 20, 2012 | 09:47 AM
dirtydog's Avatar
dirtydog
Moderate User
I know there are 3rd Gen haters when it comes to comparisons...but......
Fluid specs should be identical for 3rd and 4Gen Rams as they use same trans, front&rear diffs..etc. Only one I'm not sure of is coolant if dodge changed the radiators from 08-09+ due to increased hp?
https://dodgeforum.com/forum/3rd-gen...nce-specs.html
Old Jul 20, 2012 | 11:07 AM
Mikeyyy816's Avatar
Mikeyyy816
My manual just states the type of oil to use...not capacity. Mine is a 2009 as well...
Did dodge use different manuals for each 09, depending on when it was manufactured? I've noticed on this forum and others, one will state one thing out of there manual and others will state one thing...just baffles me. In my hard copy in my truck it doesn't state anything nor does the copy on my computer. This is quoted from my manual on my hard drive.
Front Axle — Four-Wheel Drive Models
GL-5 SAE 75W-90 (MS-9763) or equivalent.
Rear Axle
MOPAR Synthetic Gear Lubricant SAE 75W-140 (MS-8985). Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPAR􏰁 Limited Slip Additive or equivalent.
Old Jul 20, 2012 | 11:20 AM
oldjeep's Avatar
oldjeep
Rear Axle
MOPAR Synthetic Gear Lubricant SAE 75W-140 (MS-8985). Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPAR�� Limited Slip Additive or equivalent.
I'm talking about the factory service manual - not the thing in the glovebox
Old Jul 20, 2012 | 11:23 AM
Mikeyyy816's Avatar
Mikeyyy816
Agh Damn... Miss read whet you wrote the first time lol. You did write "service manual" not owners manual! Haha.
Sorry for the thread hijack Op..
