Last edit by: IB Advertising
Browse all: Dodge Ram 1500 Exterior Guides
- Dodge Ram 2009-Present: How to Replace Side Mirror
Step by step intructions for the do-it-yourself repairs.
Side view mirror LED's
I have an '09 with the courtesy and turn signal ligts on the side view mirrors.
ON the drivers side, I noticed the courtesy lights stopped working and the turn signal ligs appear weak.
Is this a known issue? Any suggestions?
On the regular mirrors the lens is a little tricky but comes out, on the tow mirrors it is super easy, small screwdriver, pops them out, and 2 small wires are clipped to them, I took mine out when they went out, drilled them out and installed the leds of my choice, I went with blue, it really looks good to me, at night the whole ground lights up blue.
Any body part and non-mechanical parts are covered under the basic bumper-bumper warranty.
If it happened at 37kmi, I'd see if the dealer would still cover it. Worth a shot because it could havebeen out the past 1-2kmi and just never noticed it.
I was being sarcastic, hint the (joking) underneath my statement.
Trending Topics
didn't even see that..
I must have took it as your signature. I never look at people signatures really.
Also, I'm wondering if the LEDs themselves are really my problem. LEDs are supposed to last something like 30,000 hours. I doubt all three LEDs in that module died at the same time?
Rob
Rob no problem, just take out the lense and get your volt meter ,unclip the 2 wires and put your volt meter on DC, press your unlock on your remote and you should see 12 volts till the relay shuts off, if you dont you have other problems, if you do you need LEDs
Here are some colors and there names , the original in mine were cool white
I changed mine out to blue, liked them better,
but I still bought some cool whites just in case, here is where I bought them from,same place i bought my front Ram eyes ,and my rear Ram eyes, yuo can use 3mm or 5mm, just depends on what you like
http://lighthouseleds.com/pre-wired-...pre-wired.html
hope this helps
hope this helps
