Can 305/55R20 tires work w/aftermarket wheels (no lift)?
4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Wondering if there is a way to use 305/55R20 tires (or similar size, i.e. somewhat wider than stock 275/60R20) if I got aftermarket wheels that had some type of offset? This would be on a 4x4 crew 1500 with no lift or level kit installed. If so, what offset is needed?
I don't really want to dump money into new wheels but I'm just looking at options...
Less sidewall height probably equals a stiffer ride. If I'm going to 305 tires they will weigh 10-20 lbs more per tire which will already make the ride more harsh. No need to make it worse with tire diameter reduction.
Rob
I'm looking at a set of General Grabber AT2's. There rated as a XL tire. I had a set of BFG's on my 07 that were rate an E tire and were a rough ride. I need a GOOD snow tire and the Grabbers are rated high for snow traction and I hope not a stiff E rated ride.
I have a set of 20x10 wheels, -24mm offset on a set of 305/55/20 NTG's. I've run this setup at stock height and also with a front level (2.5")...no rubbing in either situation.
