11 Ram 2500 Hemi not starting
Hello I have a 11 Ram 2500 Hemi and this morning it wouldn't start, I thought the fuel pump could b the issue but I called dodge and they said I could have an issue with the key? Anyone else run into this before ?
Need a bit more info on the non start issue. Does it turn over? How many miles? Anything done to it lately? Plugs good? Tune up been done? Battery good? CEL on? Can't read minds so you need to add a lot more detail.
https://dodgeforum.com/forum/4th-gen...ump-issue.html
The search function is a powerful ally.
Sure, it could be the security key. But I don't know how "Dodge" could diagnose that over the phone. 2011s are known for fuel pump failures.
The truck turns but it won't ignite almost like there is no fuel going to it. Dodge didn't diagnosed the truck over the phone the guy just told that would be a start as far as the key fob goes. The fuel pump is still in national back order and there is no tell when they can get it, I read the other thread and they r all talking about fuel pumps, so I figured I ll ask about the fob
The truck has 80k miles, battery is good and when I turn the key the motor just turns and turns but no ignition.
It's the fuel pump relay...had this exact same issue on my 2011 Durango. Fuel pump was replaced, problem remained...then the relay was replaced, problem went away.
Trending Topics
Welcome to the forum, SCghostrider! There are a couple of flash update TSBs involving no start conditions that may be related to what you're experiencing. I would recommend having an FCA dealer check this out and referencing the TSBs, pasted below.
TSB 08-024-11 REV. A
SUBJECT:
Flash: Intermittent No Start Or Intermittent RKE Function
OVERVIEW:
This bulletin involves flash reprogramming the Wireless Ignition Node (WIN) with new software.
MODELS:
**2011 (DD) Ram 3500 Cab Chassis**
**2011 (DJ) Ram 2500 Pickup**
**2011 (DP) Ram 4500 / 5500 Cab Chassis**
2011 (DS) Ram 1500 Pickup
**2011 (DX) Reg Cab Chassis (Mexico)**
2011 (LC) Challenger
2011 (RT) Caravan / Town & Country
2011 (W2) Grand Cherokee (CKD)
2011 (WD) Durango
2011 (WK) Grand Cherokee
NOTE: This bulletin applies to **DD, DJ, DP, DS, DX** vehicles built before April 7,2011 (MDH 0407XX) equipped with Remote Keyless Entry (Sales Code GXM).
NOTE: This bulletin applies to LC, W2, WD, WK vehicles built before April 7, 2011 (MDH 0407XX).
NOTE: This bulletin applies to RT vehicles built before April 12, 2011 (MDH 0412XX).
SYMPTOM/CONDITION:
The service flash corrects the following conditions:
• Intermittent no start
• Intermittent RKE function
The above conditions may be caused by a software lockup in the module. The lockup condition may be cleared by removing and reinserting fuse M27. Flash reprogramming the WIN will correct these conditions.
TSB 08-053-11
SUBJECT:
Flash: Vehicle Theft Alarm Intermittently Sounds, No Start
OVERVIEW:
This bulletin involves flash reprogramming the TIPM with new software.
MODELS:
2011 (RT) Town & Country / Grand Caravan
2011 (DJ) 2500 Pickup
2011 (DS) 1500 Pickup
2011 (DX) (Mexico) Reg Cab Chassis
2011 (D2) 3500 Pickup
2011 (JK) Wrangler
2011 (J3) (CKD) Wrangler
2011 (J8) (CKD) Wrangler
2011 (KA) Nitro
2011 (KK) Liberty
2011 (K1) (CKD) Cherokee
2011 (WD) Durango
2011 (W2) (CKD) Grand Cherokee
NOTE: This bulletin applies to RT, DJ, DS, DX, D2, JK, J3, J8, KA, KK, K1, WD, WK, and W2 vehicles built prior to May 9, 2011 (MDH 0509XX) equipped with Security Alarm (sales code LSA or LSB) or Premium Security Alarm (sales code LSC).
SYMPTOM/CONDITION:
The customer may complain of following conditions:
• The vehicle theft alarm intermittently sounds for no apparent reason.
• Multiple attempts are required to start the vehicle before the vehicle will start.
SUBJECT:
OVERVIEW:
MODELS:
2011 (WD) Durango
SYMPTOM/CONDITION:
TSB 08-053-11
SUBJECT:
OVERVIEW:
MODELS:
2011 (JK) Wrangler
2011 (KA) Nitro
2011 (KK) Liberty
2011 (WD) Durango
SYMPTOM/CONDITION:
