Online Service Manual Problem
Anyone else having trouble getting the 2009 Dodge RAM Truck 1500 Service, Diagnostic, and Wiring Information online service manual to pull up? Worked fine the last time i used it several months ago. Using IE (11) SVG Viewer installed
Needs to run on IE8 I believe, SVG viewer is not supported in later versions of IE. Also needs to run on Windows XP. I'm sure there are work-arounds that I'm not familiar with.
I used to view it on Windows 7 running a ******* PC for windows XP. Moved to windows 10 and lost that.
Internet explorer updated unexpectedly on the newer PC. Looks like I'm going to have to keep the old XP around a little longer until someone is nice enough to link an updated online service manual platform.
https://www.fleet.chrysler.com/FleetHome/SpecialtyVehicleDocs/RAM_1500_SSV_Upfitter_Guide.pdf
You can go here without putting your computer into a low security mode.
Not everything. Still more than the average joe needs to do his own work.
It is a large number of pages and takes a while to download.
Chrysler moves it around -- so if the link stops working just google it.
You can get it to work with IE 11, basically you need to setup a local webserver and then access it through there rather than via c:\ it is a security issue where you cannot lower the security enough to run SVG viewer when the source is a drive. I am running it under Windows 10 without an issue.
Mine is accessed like this:
http://localhost/Service%20manual/co...ml/default.htm
