interior water leaks
hey fellas
i have a 2010 dodge ram 2500 6.7 cummins
it recently started having water leaks inside when it rains...
it leaks from both front pillars and at the overhead console...
anybody have this issue? if so let me know any fixes or what exactly the prob was
thanks
thanks
hey fellas
thanks
thanks
Thanks for the follow-up. I'd recommend establishing a dealer appointment for diagnosis and repair. Let me know if you're in need of assistance doing so. - Kevin T, Social Connect Team
Do you have a sunroof? Mine leaked at the pillar handles due to a clogged drain line from the sunroof. Runs from the front drivers side sunroof opening through a tube down along the pillar and exits the truck in the fender just forward of the upper driver door hinge. Others had the third brake light leak into the headliner.
and the third brake light leak i fixed
i thought i was the only one with that sorta leak
appreciate the info
thanks
appreciate the info
thanks
Trending Topics
Where is this tube located at the sunroof? My '15 2500 is doing the same thing, bought it new in February of this year. Getting nothing but run around from dealers. 55K on a truck and FCA won't take care of owners.
there are two tubes
each front corner of the sun roof.
if you remove both front pillars youll see the tubes running down to the side of the cab when u open the front doors.
but i will mention, my leak turned out to be not in the sunroof but the top cab lights, the gaskets were no good anymore
hopefully that helps
