2009 QC rear door lock intermittent
Old Jun 17, 2016 | 08:13 PM
WESIDE's Avatar
WESIDE
Default 2009 QC rear door lock intermittent
Hey fellas. 2009 ram QC. So I did a little digging on the internet and found that this is a common problem. Im going to look at the wiring in the boot that connects the door to the chassis first. I was wondering if any one knew what wire colors I should be focused on? I also read about a tsb that re routes a pigtail from the factory location inside the door? Any feed back would be great. And Happy Fathers Day to all of you out there. Thanks
Wes
-Also, It looks like the latch assembly isn't covered under the max care warranty. Looks like I will have to swap that out if the wires are not the issue.
Old Jun 18, 2016 | 12:23 AM
Friar Tuck's Avatar
Friar Tuck
Lightbulb Recalls
http://www.dodgeproblems.com/tsbs/Ram_1500/2009/
Old Jun 18, 2016 | 10:46 AM
WESIDE's Avatar
WESIDE
Good info on TSB's. I didn't see any relating to my issue though.
Old Jun 19, 2016 | 02:43 AM
Friar Tuck's Avatar
Friar Tuck
Talking
I didn't either, but it'll give you something to read when there's nothing on tv
I don't have an '09 manual, but if I can find one I'll get back to you.
Old Jun 19, 2016 | 03:12 AM
Friar Tuck's Avatar
Friar Tuck
Lightbulb
Left Rear Door Connector 306
pin 1=unlock---tan/orange
pin 2=lock------tan/violet
Right Rear Door Connector 320
pin 1=unlock---tan/light blue
pin 2=lock------tan/dark blue
Hope this helps.
Old Jun 19, 2016 | 01:16 PM
WESIDE's Avatar
WESIDE
Awesome. Thank you.
Old Jun 24, 2016 | 02:36 AM
Friar Tuck's Avatar
Friar Tuck
Is it fixed?
Old Jun 25, 2016 | 04:09 PM
WESIDE's Avatar
WESIDE
I picked up a new actuator from the dealer for about $115 and I had time today to open up the door panel. Dismantling was pretty simple and I just followed some simple steps I found off another forum. I didn't need to take off the window holder bracket thing. I'm assuming you may need to for the front doors. Only issue I had was re clipping the window back into place on one side. Took a little patience and finesse. I didn't bother taking a look at the wiring because once the old actuator was out I could tell it was sticky and not locking into position correctly like the new one. Fairly simple and straight foreword fix. Thanks for the wire info.
Wes
Old Jun 26, 2016 | 01:01 AM
Friar Tuck's Avatar
Friar Tuck
Good stuff, glad you got it fixed and thanx for letting us know.
