Hey fellas. 2009 ram QC. So I did a little digging on the internet and found that this is a common problem. Im going to look at the wiring in the boot that connects the door to the chassis first. I was wondering if any one knew what wire colors I should be focused on? I also read about a tsb that re routes a pigtail from the factory location inside the door? Any feed back would be great. And Happy Fathers Day to all of you out there. Thanks
Wes
-Also, It looks like the latch assembly isn't covered under the max care warranty. Looks like I will have to swap that out if the wires are not the issue.
Wes
I didn't either, but it'll give you something to read when there's nothing on tv
I don't have an '09 manual, but if I can find one I'll get back to you.
Left Rear Door Connector 306
pin 1=unlock---tan/orange
pin 2=lock------tan/violet
Right Rear Door Connector 320
pin 1=unlock---tan/light blue
pin 2=lock------tan/dark blue
Hope this helps.
Hope this helps.
I picked up a new actuator from the dealer for about $115 and I had time today to open up the door panel. Dismantling was pretty simple and I just followed some simple steps I found off another forum. I didn't need to take off the window holder bracket thing. I'm assuming you may need to for the front doors. Only issue I had was re clipping the window back into place on one side. Took a little patience and finesse. I didn't bother taking a look at the wiring because once the old actuator was out I could tell it was sticky and not locking into position correctly like the new one. Fairly simple and straight foreword fix. Thanks for the wire info.
Wes
Wes
