Rear Dome light issue
2015 RAM SLT Quad cab The dome light above the rear seat does not work. The front map light do! Bulb is fine ever picked up a new one still NG.. No fuse listed in the manual so have no clue what it is hooked up to, Is it controlled by the computer? I did test for power and have 12v both sides of bulb to ground on 12v plug ! Will be going to dealer in a couple weeks to do winter tire swap if it ever stops snowing lol any idea where I can look?
WOW 189 lookers at this post and no one had any ideas on where to start or what it may be :O ,, I will update in case anyone else has a similar issue. It was a Ground Pin pushed out, Simple fix so I was on the right track
