HTML issues?
HTML issues?
<\\;P>\\;It appears that there&rsquo;s a new issue starting today...&\\;nbsp\\; When you post a new note everything looks fine in the editor, but when you submit a note there&rsquo;s all sorts of HTML paragraph markup tags appearing in the posts.<\\;/P>\\;
<\\;P>\\;&\\;nbsp\\;<\\;/P>\\;
<\\;P>\\;The poll system is still down.<\\;/P>\\;
RE: HTML issues?
I was just going to ask about this problem, but I see I'm not the only one having difficulties. Very annoying to have it change like this. Anytime you add an apostrophe it doubles the number.
Here there should only be 1: '
Here there should be 4: '
But when I hit submit it will probably be 2 and 8 respectively.
Code:
from I'm to I'm, etc.
RE: HTML issues?
That apostrophe issue is still an issue. It before was what was making half the html code show so last night I just typed without using them even though it was hard and I had to go back and erase them since I use them out of habbit. That and having blank likes like hitting enter to skip down made it do that also. Today that seems to be fixxed but there is still that issue where it doubles up the apostrophes.
