network connection setting issues
im usually pretty good with computers but i just cant figure this one out, it comes and goes, and i only seem to get it when im plugged into my own internal network (wired or wireless)on campus (i have my own wireless router set up in my room on campus which i connect to most of the time) when i am connected to the schools wireless network i dont seem to get the issue. The connection just drops at random and stays down for a while, but it always comes back on its own. when the connection drops and i click on the "troubleshoot connection problems" icon this is what it "finds"
any help would be great, iv tried everything i can think of and cant get it fixed
EDIT: this is on windows 7 BTW
Just so we're straight here...
You have a dorm room on campus. You have a wireless router plugged into an ethernet jack in this dorm room. Correct?
My network experience is mostly limited to smaller networks, however, I believe this problem is at least partially related to the fact that you have a router plugged into an ethernet jack that has a cable that travels for who knows how many feet to a switch, which probably has another ethernet cable(s) that travel to another switch or firewall, which probably goes to a router (or it may be one device thats a combination of the last two or three).
The problem, in summary, may be because whenever you try and "stack" two routers in the same network, one plugged into the other (or communicating with each other via switches), you usually get problems unless you turn at least some of the "routing" features of the second router off.
It also could be a router problem. Which brand and model of router are you using?
im also having the same problem it drops randomly and comes back... but mine is in a home im using the motorola wr850g i just cant figure this out... and im good with this kinda stuff. im also running off windows 7 release client
jasonw you are pretty much correct, but im just down the hall from the network room in this building maybe 50 feet max, and yes i have my router running as a router, i want the security of not just anybody being able to access my server, and other people seem to running similar setups without any problems
the router is a netgear wgr614v9
also, i do know that the school has one firewall between their routers and the internet, none besides that as far as i know, and idk if this is relevant, but each computer gets an IP on the internal network which is the same as what shows up on the outside (as if you are on a modem which is set up as a dmz host to forward all traffic through to one computer)
What computer are you connecting to this router with? Does it drop no matter what PC you use, or does it seem that one computer has more drops than another?
How old is the router?
Normally, a router is set up to acquire its IP from the ISP, in this case, your school's network. If there is a router on router miscommunication, so to speak, your router may try to renew or acquire its IP address or some other settings and it can't get one/them.
Basically, try to fill in things manually as possible, rather than letting the router "automatically" do this or that. Note: Back up your current settings so that, if you really mess something up, you can at least go back to your partially working setup.
actually i have to have it setup to automatically detect the ip address, (the school wouldnt allow it to connect when i had it set up to request a static IP
)but i do have my own DNS server address programed into it, and at the place i worked this summer we used netgear hardware almost exclusively, but iv been thinking about getting myself a wireless N gigabit router and setting this one up at home as a wireless access point/network switch in my room
i actually tried setting the router up with DD-WRT but it doesnt work without modifying the hardware which im not willing to do, if you know of any other open-source firmware id be more than willing to try that, i also checked the firmware and flashed it to the newest version i could find on their website
)but i do have my own DNS server address programed into it, and at the place i worked this summer we used netgear hardware almost exclusively, but iv been thinking about getting myself a wireless N gigabit router and setting this one up at home as a wireless access point/network switch in my room i actually tried setting the router up with DD-WRT but it doesnt work without modifying the hardware which im not willing to do, if you know of any other open-source firmware id be more than willing to try that, i also checked the firmware and flashed it to the newest version i could find on their website
both my pcs seem to do it equally. both are run wireless if that has anything to do with it im not sure.
Trending Topics
okay there is one thing here that has failed to be asked, I saw some where up there dorm/school. Does the school require you to run some sort of software?
Second, what do you use to find viruses spyware trojans worms, that sort of thing.
Lastly do you download torrents, access off the wall sites?
Most of the schools that I have had to work on have had some type of SPI (Stateful Packet Inspection) Most run Bradford Persistince agent. Some run others. Heres the thing. If both machines are getting knocked off at the same time, the connection to the router is begin severed. If not it is the router. Lets go this route, do they require students to register game consoles mac addresses before they can get them online?
If so you can try to set the router mac as one of the game consoles you will knock off whoever is online, but if you run great they are mac filtering the gameconsoles, and there fore either by you yourself or a piece of software on the pc you are accessing something they dont want you to, say a certian port or site, perhaps even public IP address.
Ill wait to say more untill I see some replys from you on some of the questions that I asked.
ok dorm room connection is correct, yes they require you to register the ethernet connector mac address in order to get a game console/second computer online, i have that mac address set to the routers mac address, i am not access any off the wall sites, and i run comodo internet security as my a/v and firewall software, and the second computer (actually functioning as a server) is running linux so i have nothing running on there except my samba share and ventrillo server
If you have a buddy with a spare wireless router, try replacing the netgear. I never had much luck with netgear products nor dlink products working consistently. The only product that I used and is pretty reliable is Linksys products. Now built by Cisco, it is a better product. We use linksys wireless access points in most of our small satellite offices. I installed lots of linksys wireless routers in alot of homes and so far, no one came back to complain of any connectivity issues. Plus some linksys products, they have all kinds of cool features not found in most other products.
