Dodge Forum Site Issues and Suggestions Having an issue with the DF software? This is your section!
PDF File
Old Jan 14, 2010 | 07:45 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default PDF File
Hi
I want to start a sticky thread, instead of typing it out on the key board. Is the there a way to cut and paste the pdf file to the thread that want to start? If so how would i go about it. Thank you
Old Jan 23, 2010 | 09:55 PM
Altair's Avatar
Altair
Dak attack!
You should be able to use the text select tool to copy everything, you will likely have to redo the formatting though.
Old Jan 25, 2010 | 04:20 PM
master tech
Thank you, I was able to do what was needed. And did the stickys. When you get chance look at the van section.
