Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
Need help removing the multifunction switch
Old Nov 22, 2009 | 08:34 PM
Red Intrepid's Avatar
Red Intrepid
Default Need help removing the multifunction switch
i have a 1994 intrepid 3.5l and need to replace my mfs. however, i can't seem to open up the cover that houses the ignition lock and directional, etc. the pic shows the hole where there must be a screw or something holding this together, but i can't seem to figure out what it might be. the haynes manual i have doesn't help. thanks in advance for any insights.
Attached Thumbnails Need help removing the multifunction switch-mfs-switch-question.jpg
Old Nov 22, 2009 | 10:16 PM
92dak5.24x4's Avatar
92dak5.24x4
Haynes manuals are useless for this. there are several Torx screws to remove. I believe they are T15 for size
Old Dec 26, 2009 | 07:46 PM
gn300's Avatar
gn300
Every hole has a screw.
mine had been replaced once so there were phillips screws in it.
There is a how to at www.dodgeintrepid.net
