Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
transmission hard shift from first into second
Old Mar 8, 2010 | 07:30 PM
zwisen's Avatar
zwisen
Default transmission hard shift from first into second
hey guys trying to help my folks out here. they have a 2001 intrepid se 2.7v6 with 109,000 miles. there having a problem when it shifts from first into second gear. i has a hard jerk motion and then slams into gear. it only does this from first into second. all other gears are fine. the dash light for the transmission is on. i looked for codes but nothing came up. any ideas or thoughts to try would be appreciated . thank
Old Mar 19, 2010 | 01:02 AM
lennemann23's Avatar
lennemann23
The codes you looked up are probably just the pcm codes. You need to get your tcm codes ran. It requires a DRB scan tool. Take the car to a mechanic that has this tool and it take seconds and they will tell you that the problem is. It sounds like either it's low on transmission fluid or the transmission needs to be re-programed.
Old Jul 25, 2013 | 09:06 PM
chromedom's Avatar
chromedom
Did you find out what was causing the hard shift into second?
