2001 3.2L intrepid powersteering leak.
hello everyone, i have a problem with my 2001 intrepid powersteering line is leaking, i dont know if its the return line or the high pressure line. the line from the rack to the pump is not leaking is that line the high pressure or the return?? the other line is the one that is leaking and it runs from the rack looks like it goes to the rad area is that the low/return line? if that is the low return line is there any way i can cut out the bad area and clamp in a new rubber hose?? its leaking on part of the steel line.
Thanks
Thanks
