Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
97 Intrepid
Old Jun 26, 2010 | 10:24 PM
dcoperator's Avatar
dcoperator
Default 97 Intrepid
I've got a 97 Intrepid ES 3.5 . It will start right up in the morning but after arriving to a destination it starts very hard. Like it is starving for fuel.Got 60,000 mis. on it. Once its started it runs fine...Any thoughts?
Old Jun 27, 2010 | 08:52 PM
kurts2's Avatar
kurts2
So many things could do this. You need to isolate which system is malfunctioning. Air, fuel, or fire (spark). My guess is fire (spark). Specifficly the timing is out when the engine is warm/cooling. Start with a plug change, air filter, fuel filter etc Then do a fuel pressure test to include testing the fuel pressure regulator.
Any codes? Also do the key trick and see if you get any thing other than 55.
Old Jul 4, 2010 | 08:53 PM
dcoperator's Avatar
dcoperator
Can you elaborate on the "key trick" ?
Old Jul 4, 2010 | 09:10 PM
kurts2's Avatar
kurts2
Sure turn the key from off to run three times and then stay on run (by run I mean the key possition before the starter turns over). The engine lamp will flash two digit codes eg blink blink pause blink pause pause then the next code. 55 is the last code to let you know it's done. A 55 by itself is not a fault, only the other numbers. These "MIL" codes are not the same as the p code from a scan tool and need to be looked up seperatly. Just let me know if you get any codes.
Old Aug 11, 2010 | 10:40 AM
rezonator's Avatar
rezonator
could posibly be o2 sensor
Old Aug 11, 2010 | 11:56 AM
sapporo's Avatar
sapporo
absolutely not for this explained problem.
Old Aug 11, 2010 | 12:26 PM
rezonator's Avatar
rezonator
why would you say that?
ive experienced that problem myself, not saying that is his problem but is a posibilty
Old Aug 11, 2010 | 01:15 PM
sapporo's Avatar
sapporo
so you're basically telling the guy to replace his oxygen sensor(s). Why not tell him how to diagnose them so he can verify they are defective... and because you can't spell possibility.
Old Aug 11, 2010 | 02:38 PM
rezonator's Avatar
rezonator
mabe you should read the post one more time as i said "mabe"
i never said to replace them!!!
didnt know i was being graded on my spelling
Old Aug 11, 2010 | 03:07 PM
sapporo's Avatar
sapporo
"mabe" as in Tom Mabe? He's freaking hillarious!!!
Why not just list off all the sensors that could possibly be the problem?
Not taking the effort to correctly spell, even simple words, shows a lack of quality.
