Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
02 Intrepid Shifting problems???
Old May 15, 2011 | 07:38 AM
Maintenance_man2009's Avatar
Maintenance_man2009
Default 02 Intrepid Shifting problems???
I have an 02 and an 03 Intrepid SE, one silver and one blue, not that it matters :-)
Anyway, both cars have begun this shifting issue... Please let me explain..
When traveling at a constant rate of speed the car seems to be fine and will shift like it is supposed to, while getting there. However, if you let off the accelerator as when slowing for traffic or coming upon a traffic light or stop sign the car will down shift and then stay there. If you stop and take off the car will shift into second but will not shift any higher. The only correction is to pull over and stop, turn the car off, and then restart. It will be fine until your speed reaches high enough to shift into third gear and then if you slow down by releasing the accelerator, once again, it will down shift (fairly hard) and then you have to do the whole process over again.
The odd thing is though, it is random and doesn't do it every time!
If anyone has experienced this or know what the solution would be to correct this issue, the help would be greatly appreciated.
Old May 16, 2011 | 11:29 AM
stlrj's Avatar
stlrj
Default Solenoid pack gone bad
Chronic problem on 02-04s.
Old May 31, 2011 | 07:46 AM
d00fy's Avatar
d00fy
i am having the same problem also bought the car 3days ago, fkin dealership and sales rep bought it as is, no warrantly , crooks
i had the same problem with 2002 chrysler 300m
how much does it cost to fix the solenoid pack
Old May 31, 2011 | 10:26 PM
stlrj's Avatar
stlrj
~$250-300
Old Mar 5, 2012 | 06:29 PM
motherof4f's Avatar
motherof4f
New Member
Default Me to
OMG I have this EXACT same problem!!! When I pull over and restart it....it is fine!! So everyone tells me it's not the transmission. How do I fix this on my 02 Dodge Intrepid.
Old Oct 8, 2012 | 12:05 PM
Cblanning22's Avatar
Cblanning22
Same problem in my 04 Intrepid. I replaced the PCM and never had that problem again. Cost me about 500
