Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
idles
Old Nov 11, 2011 | 11:44 PM
dj duck's Avatar
dj duck
Default idles
So I came home from work yesterday and parked my 99 Intrepid with 2.7L. I then had to go back out an hour later and try to go, but no luck.
Well the car starts, but as soon as I touch the gas, it stalls. I turn it off and try again and same thing. It will idle, but nothing more than that. I checked the codes by turning the key and got:
PO123
P0122
P0106
P123
P0405
So basically it is saying that the proper voltage is not getting to the TPS, EGR and MAP sensors.
I tried swapping the TPS from my parts car, also a 98 with 2.7, and no luck. Then I swapped the computer, and still the same thing. It idles but that is it.
Also brought a new Map sensor
Has anyone run into this problem before? Any suggestions
