Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
check engine light burn out?
Old Aug 22, 2012 | 09:08 PM
mcbockalds's Avatar
mcbockalds
Default check engine light burn out?
2002 Intrepid. The check engine light does not light up (ignition on) all other instrument panel light do light up. Is it burned out? I got into the dash and the check engine light (led?) sure appears to be "hard wired" in place and will not pull out. What to do to fix?
Thanks
