Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
Air Filter Bolt - Nut Turns
Old Oct 14, 2012 | 02:18 PM
Sibenjam's Avatar
Sibenjam
Question Air Filter Bolt - Nut Turns
Hello, I don't know if the air filter in this car has ever been changed, but when I tried to remove the plastic cover, the nut that is molded into the underside of the housing turns as I turn one of the bolts. I have tried holding it through the housing with vice grips but I can't get a good enough grip on it to unscrew the screw. Does anyone have any suggestions? Thanks in advance.
Susan
Old Feb 2, 2013 | 07:31 PM
steak59's Avatar
steak59
drill the bolt off, and replace the bolt and the u-clip on the bottom.
