Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
oil light on, engine shut off, oil level good
Old May 1, 2013 | 09:19 PM
rolguin's Avatar
rolguin
Default oil light on, engine shut off, oil level good
Driving down street the oil light came on then followed by lack of power then engine shut off, checked oil and all other fluid levels all good. Towed car home checked all fluids,belts, etc... tryed starting all was good except oil light still on, changed oil looked for signs of metal in oil all was good restarted engine ran for 15-20 min then shut off. Any help appreciated
Old May 4, 2013 | 09:37 AM
go-part's Avatar
go-part
Former Vendor
http://www.popularmechanics.com/cars...ome-on-8657725
Old Aug 10, 2013 | 07:00 PM
97 3.5 Intrepid's Avatar
97 3.5 Intrepid
which engine does your car have? If it is a 2.7L V6, you might have an oil sludge problem a brewing. The best advice I have is to switch it over to synthetic.
If not, when was the last time you had an oil filter change. It is possible that you might have a defective filter if it was recent or that the filter might have failed. An oil filter is cheap and easy to replace. My advice would be to get a better quality oil filter with mid range efficiency (Wix/Napa Gold, Purolator Classic, or Mopar/Motorcraft equivalent) and see if it improves or go for complete over kill (Napa Platinum, Purolator Platinum, FRAM Ultra, Amsoil, Royal Purple) which flow very well and are very efficient. A filter that is extremely efficient using cellulose based media (Purolator PureOne) might not flow well enough, and some cheap designs (STP, Microguard, AC Delco "-E" series, Supertech) I have heard of people having problems as their by-pass system is lacking at best.
If not that, you might have an oil pump problem, in which you would need a more professional opinion
Old Sep 11, 2013 | 03:24 PM
LESchwartz's Avatar
LESchwartz
Wat engine do you have? How many miles are on it? How often do you change the oil? Do you change the filter at the same time? What oil and filter do you use?
In the absence of any other information, I would suggest an oil and filter change. If that doesn't solve your problem, you can check the oil pressure with a gauge to ensure your sending unit is good. If the oil pressure really is low, it might be time to drop the pan for a bottom end inspection.
Larry
Old Feb 13, 2023 | 11:56 AM
mike paner's Avatar
mike paner
