Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
09 Headlights
Old Mar 22, 2011 | 07:57 AM
Default 09 Headlights
Anyone have issues with really dim/crappy headlights on their Journey? Both low and high beam. I have tried replacing with higher wattage bulbs but still can hardly see out the front of this thing. I drive around with my high beams on and people dont even flash me. I am currently running 100 watt bulbs in the high beams and 80 watt in the low beams but still can hardly see the road in front of me. Checked the aim as well. Seems to be a design flaw with the reflectors. I guess my next option is installing HID's but dont know if these would work well with regular reflector housings....anyone have the same issue or other ideas? Mine is an SE so there are no fog lights, that was another route I could take is to add foglights but then I have to get the stealer to flash toe computer so they would work....
Old Mar 22, 2011 | 08:37 AM
HammerZ71's Avatar
HammerZ71
I've only driven my mom's at night once. About an hour and a half trip when I took her to a relatives funeral. I didn't notice where the headlights were any worse than the ones in my Grand Cherokee. She hasn't complained, but it wouldn't surprise me if she's never driven it after dark.
Don't waste your $ on the fogs though, you almost can't tell they are on when you switch them on...
Old Mar 24, 2011 | 07:59 AM
Thanks Hammer!
Old Mar 24, 2011 | 10:08 AM
HammerZ71's Avatar
HammerZ71
Yep, I believe the fogs are only something like 20 watt, and there are NO aftermarket bulbs that fit the connector at this time...
Old Mar 24, 2011 | 03:11 PM
20 watt?? how lame.
Old Mar 25, 2011 | 01:50 AM
steak59's Avatar
steak59
You can Fit Some of the H16/9009 in there, or H16 HID. used by GM mainly, roughly 42watts. But Dodge used 20watt bulb because they are using el Cheapo Fog Lense/housing. 42watts might melt it. Besides, fog doesn't help much on lumination.
HID will be the way to go! Besides, HID is almost as cheap as a quality Light bulb nowaday.
Keep running 80-100watts bulb will Melt the Wiring harness or the Head Lamp Bulb inlet, they are too hot.
Or you can Install an Off-Road light rack on ur Roof like a Jeeps.
