Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
09 Journey rear LH doorlock
Old Apr 3, 2012 | 09:14 PM
Rick Logan's Avatar
Rick Logan
Default 09 Journey rear LH doorlock
Hi, new here, our 09 rear LH door lock will no longer function, it will on occasion, but most of the time not, I am assuming that it is the actuator that is the cause. can anyone step me through checking this out? And replacing it if needed?
Thanks
Old Apr 4, 2012 | 11:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF Body/Doors - Rear/LATCH, Door/Removal
REMOVAL
1. Remove the door trim panel.
2. Remove the door module assembly.
3. Remove the latch assembly from the rear of the door module by disengaging the clips.
4. Disconnect the latch cable and rods from the latch assembly.
Old Apr 4, 2012 | 11:32 PM
Rick Logan's Avatar
Rick Logan
REMOVAL
Thank you, could you help me with how to remove the panel?
Thanks
