Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2010 Dodge Journey
Old Feb 25, 2013 | 11:44 AM
Dan Robinson's Avatar
Dan Robinson
Default 2010 Dodge Journey
Yesterday I started my Journey and all the gauges kept "resetting" and the wipers were on all by themselves, now today it will not start, just a "click". The battery is fine and has fuel. Just hoping to get some advice to maybe get it running again.
Old Feb 25, 2013 | 03:21 PM
bigtsr's Avatar
bigtsr
Typically this still looks like a battery problem.
All late model computer driven Mopars will experience
wierd symptoms with lights and radio working and still
not start,had that on my Caliber.
Before you try anything that costs money disconnect
positive and negative battery terminals,clean posts
and cable clamp-ons thoroughly.
Don't hurry as it will allow set charge on system disapate
you can also touch + - cables together to speed up process.
This allows TIPM to reset-reassemble and try starting.
Old Feb 25, 2013 | 04:23 PM
Dan Robinson
replaced the battery, it does start now but original symptoms persist.
Old Feb 25, 2013 | 09:46 PM
steak59's Avatar
steak59
You got a V6 or a 4 banger? do you have aftermarket alarm?
Put your shifter in Neutral, and see if it starts. The Journey have problem with the Park/Neutral switch.
If that doesn't work, you might have to tow it to the dealer. Sound like you got a bad starter, or electrical issue.
Old Feb 26, 2013 | 07:39 AM
Dan Robinson
It now starts with a new battery but all the gauges and idiot lights still go on and off every 2 seconds and the wipers come on by themselves.
It has a V6
Old Feb 26, 2013 | 07:56 AM
bigtsr's Avatar
bigtsr
I would say that it's a CANBUS problem as wipers signal
goes thru clockspring assy and cluster signal does not.
Somehow CanBus is enabling TIPM actuations of these
2 things,definitely a dealer visit.
Might be as simple as poor connection at TIPM.
