Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Dodge journey rear wiper issues
Old Apr 10, 2014 | 12:28 AM
Ppcdc30's Avatar
Ppcdc30
Default Dodge journey rear wiper issues
I have a 2009 Dodge Journey SXT AWD and I have started to have a problem with the rear wiper. When. It operates on the intermittent setting it just continues to run without pausing and when you turn it off it stops where it is on the window without going back to the home/stored position. The washer fluid function works fine also. I have tried disconnecting the battery to resolve it and did not help. When you turn the switch on the column on you can hear a relay switch on under the hood in the fuse box. I cannot locate which relay it is because they did not mark them for some reason.
Has anyone had this problem before or able to help me in directing me in a direction to fix or possibility of which relay that controls this so I can isolate it without taking it to a dealer to put it on a computer to see what the issue is.
Old Sep 1, 2018 | 01:41 PM
Heather Marsel's Avatar
Heather Marsel
Default Same!
FINALLY SOMEONE ELSE HAS THIS ISSUE. Not that I enjoy your issue, but you’re not alone. Unfortunately, I have yet to find the solution.. any luck for you since you posted this?!?
Old Sep 2, 2018 | 08:37 AM
He had the problem 4 years ago. Haha. Check the wires inside the wire loom going from the body to the liftgate. It is a known issue that the wiring inside becomes frayed over time due the constant bending of the wires when opening and closing the lift gate.
Old Sep 4, 2018 | 10:57 AM
DodgeCares's Avatar
DodgeCares
Hi Heather Marsel,
We're sorry to hear you are experiencing this. If you choose to have your dealer look into this, you can also send us a private message and we'd be happy to provide you with extra assistance while your Journey is being serviced.
Lydia
Jeep Social Care Specialist
