Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
removing front rotors
Old Aug 31, 2014 | 07:12 AM
harleyfd1241's Avatar
harleyfd1241
Default removing front rotors
2011 journey with a warped rotor. This style has the wheel lugs threaded into the rotor, it is not bolted into a backing plate nor is it held in place with set screws or tabs. Do you need to remove the axel bearing nut and bearings to remove this type of rotor? Very befuddled
Old Aug 31, 2014 | 12:47 PM
Moving to the correct section. You have already asked this question. One time is enough.
