Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
In need of torque specs
Old Jul 5, 2015 | 08:15 AM
joemel's Avatar
joemel
Question In need of torque specs
Can anyone please tell me the 2010 Journey proper torque specs for the following: Front hub bearing bolts, caliper housing bolts, caliper guide bolts, front spindle hub nut, and lug nuts? Thanks
Old Jul 11, 2015 | 11:08 AM
joemel's Avatar
joemel
I found the specs at PartSource. Front hub bearing bolts 60 ftlbs, caliper housing bolts 125 ftlbs, caliper guide bolts 26 ftlbs, front spindle hub nut 97 ftlbs, lug nuts 100 ftlbs.
Old Feb 3, 2019 | 06:31 PM
John 96's Avatar
John 96
I have 1996 Dodge Ram 2500 and I replacing the caliper brake pads and rotor, and I want to what are the torque specs on how tight should the wheel hub mounting bolts be?
Old Apr 8, 2019 | 02:37 PM
Bambambravo's Avatar
Bambambravo
Replacing the front suspension and need torque specs for it all. Thanks
Old Feb 11, 2020 | 03:50 PM
Eric Spurrell's Avatar
Eric Spurrell
Talking Dodge Journey Wheel Hub Assembly Axel Nut Toque Specs
I found all the torque specs here:
https://www.showmetheparts.com/timken/ Simply plug in your vehicle infor and click on TORQUE SPECIFICATIONS
See Attached for the 2010 Dodge Journey as an example.
