Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Shifter
Old Mar 18, 2016 | 02:37 PM
Lindapal56's Avatar
Lindapal56
Default Shifter
Shifter stuck in neaual will not shift evening using the release key using srew driver won't shift
Old Mar 18, 2016 | 03:15 PM
DodgeCares's Avatar
DodgeCares
Which model year and type of engine is your vehicle? Any other symptoms present? Did anything occur prior to putting the vehicle in neutral that may have contributed to it getting stuck?
Old Mar 19, 2016 | 08:29 AM
This. ^^.
Please add your vehicle info.
Old Mar 19, 2016 | 09:34 PM
Lindapal56's Avatar
Lindapal56
Default Shifter
We found out what our problem is the shifter cable where it atact to transmission is seige there we have taken off the shifter cable and was told you can free this with wd40 its like a bracket that goes back and forth that where the problem is we are able to free it up now to atact shifter cable back and get the gears back right any suggestions
Old Mar 19, 2016 | 10:11 PM
Lol, what? Read that out loud to yourself.
Old Mar 20, 2016 | 09:43 AM
Lindapal56's Avatar
Lindapal56
Where shifter cable atact to the transmission on the engine I have a 2.4L engine 2010 its seige there
We were able to free this up our friend who works at Dodge told us at times you free this with WD40 it took more than that but it's free up now we are putting shifter cable back on and to get at this we had to remove aircleaner to get better access to I guess u don't know where this part is where shifter cable is atact to transmission
Old Mar 20, 2016 | 10:03 AM
From what I understand, your shifter cable was froze. You removed it and used WD40 to free it up. Now you don't know where it attaches back to the transmission. No offense, but using a little punctuation and spell check now and then would make your posts much easier to understand.
Who removed the cable?
Old Mar 20, 2016 | 10:11 AM
Lindapal56's Avatar
Lindapal56
Yes we know where to atact it back but setting to get all gears is the problem where park should be the shifter cable its like it don't reach when we atact the cable we can shift all gears but with the shifter in the car but can't seem to get park or reverse do it need to be set or something
Old Mar 21, 2016 | 01:13 PM
Lindapal56's Avatar
Lindapal56
Well got back the gears the shifter will shift still can't seem to get Park that's where we are at
Old Mar 21, 2016 | 04:22 PM
DodgeCares's Avatar
DodgeCares
If this is something you guys seem to be stuck with, I would recommend letting a dealership work on this for you. If you decide to do so and would like assistance scheduling an appointment, please feel free to reach out to me through PM!
