Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2010 Journey ESP/BAS, ABS and 2 Other alarm
Old Jun 22, 2016 | 12:54 AM
maximus2013's Avatar
maximus2013
Default 2010 Journey ESP/BAS, ABS and 2 Other alarm
Hello,
My 2010 Dodge Journey 2.4 SXT show 4 alarms indicator when I've started, I tried to reset every way but still shown.
How can I fixed this problem?
Regards,
2010 Journey ESP/BAS, ABS and 2 Other alarm-img_20160622_104931-1-.jpg
Old Jun 22, 2016 | 07:10 AM
bigtsr's Avatar
bigtsr
Have the stored fault codes read by someone with
OBD scanner , some atuo supply stores will do it.
Try disconnecting your battery for 15 - 30 minutes
to reboot CanBus system.
It could be a failed sensor.
Old Jun 22, 2016 | 07:36 AM
As stated on the other forum, a bad wheel sensor.
Old Jun 22, 2016 | 08:25 AM
DodgeCACares's Avatar
DodgeCACares
Originally Posted by maximus2013
Hello,
Regards,
Attachment 27017
maximus2013,
I'm sorry to hear about your concern. The other 2 warning lights are for the Traction Control and the Parking Brake. A diagnosis is recommended to determine the root cause.
Dave
Old Jun 22, 2016 | 09:32 PM
maximus2013
Thanks so much everyone, I will try to do your suggestion.
Regards,
Old Jul 30, 2017 | 04:44 PM
deaconite's Avatar
deaconite
Thumbs up ESP BAS Park brake Traction and ABS dashboard lights on
I had exactly the same problem and fixed it myself by jacking up rear end of van and disconnecting then reconnecting the 2 rear wheel speed sensors wiring connections. It turned out that 1 of the sensors had a dirty / loose connection. Problem solved at $0 cost. Also, if parking brake lits, problem is on the rear sensors, if not, should be the front sensors. Good luck.
Old Mar 18, 2020 | 08:28 PM
Shawn and Esther Verbakel's Avatar
Is there a way to tell which sensor it is?
Old Mar 18, 2020 | 08:35 PM
Haha, sorry never mind. I just read the above post, so i'll assume its the front speed sensors. (Thx!)
Old Aug 1, 2021 | 03:29 AM
CharlesMx04's Avatar
CharlesMx04
Default I am having the same issue with my 2010 Journey
Hello, did you find a resolution for this as I am having the exact same issue as you.
Old Aug 1, 2021 | 07:59 AM
Yes, if you read the posts, it is a wheel speed sensor.
