Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Misfire issue, at a TOTAL LOSS!! Help please!
Old Mar 12, 2018 | 11:46 PM
Jml71293's Avatar
Jml71293
Default Misfire issue, at a TOTAL LOSS!! Help please!
Ok so i have a 2010 Dodge Journey that i just bought second hand. 160,000 highway miles and it immediately after purchasing threw a check engine light. Maybe it was new, maybe the seller lied to me and covered it up, don't know, don't care. Still have to fix it. Anyway, the code is P-0304 misfire on cylinder #4. You can definitely hear the misfire at idle and feel it when taking off from a red light or stop sign but its not a dead miss. It's not missing 100% of the time. Maybe half the time? First thing i did is swap the injector, plug and coil with cylinder #3 hoping the misfire would end up on the third cylinder, but alas it stayed on number #4. Had a buddy throw a fancy computer on it a get the freeze frame. Confirmed cylinders one, two and three had zero misfires in the previous driving cycle but cylinder four had over 2,000 misfires in the previous drive cycle! Checked all sensors using the same computer and they seem good. Gave a quick inspection to the wires and plugs under the hood and there is nothing obviously wrong. Someone gave me the idea to reflash the computer so i took it in and had that done, to no avail. Put a vacuum gauge in the intake and it fluctuates between 20-21 inches in sync with the misses. Tonight it threw another code P-2311. Ignition coil on cylinder #4 secondary circuit has low ionization. I thought to check the codes AFTER my dumbass messed with a bunch of stuff under the hood, so, i have no clue if it was there earlier today, or if it only popped up as a result of something i did while attempting to diagnose the issue. Anyone have a clue what the hell could be wrong?! I'm at a total loss here!
Old Mar 13, 2018 | 07:41 AM
Time for a compression check.
Old Mar 13, 2018 | 08:51 AM
Jml71293's Avatar
Jml71293
ran one already. Came back good.
Old Mar 22, 2018 | 09:18 AM
Jml71293's Avatar
Jml71293
Noone have any suggestions?
Old Mar 22, 2018 | 11:50 AM
There was a recall for cylinder heads for some years. Might check with the dealer and see if it applies to yours.
Old Mar 23, 2018 | 11:34 AM
Jml71293's Avatar
Jml71293
I gave the dealer the VIN and they ran it for any recalls. Nothing for the heads or anything.
Old Mar 28, 2018 | 11:28 PM
Jml71293's Avatar
Jml71293
SOLVED!!! After tons and tons of time and researching i decided to spray the intake manifold gasket area with brake cleaner to check for leaks. Sure enough, the engine stalled. Replaced the intake gasket and just a couple hours later and $6 at oreilys, problem solved! Thought I'd post for anyone else because noone seemed to have a clue
Old Mar 29, 2018 | 12:12 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Grats you didn't even mention which engine you had. I'm sure everyone was lost.
