Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Running a dedicated power line
Old Mar 21, 2019 | 12:28 PM
AJWinters's Avatar
AJWinters
Question Running a dedicated power line
I need to find out if there is an already established grommet in the firewall so that I can run a dedicated power line from the battery to a new outlet. The current outlets keep tripping a micro switch every time I try and use my inverter in it and I don't want to have to spend a car payment to see if someone else can run that line for me. Thanks in advance.
Old Mar 21, 2019 | 02:49 PM
It’s just to the left of the brake booster and hidden under the rubber mat. Its right underneath the protruding rubber square. This rubber square pulls away and off to reveal a massive 2.5” grommet.
A closer shot. You can see where the rubber mat was removed::
Hole in Firewall after rubber and 2.5” grommet have been removed:
From the hood (driver’s side):
A closer shot from the hood:
The 2.5” grommet (top) and square rubber piece that hides the grommet.
Old Mar 21, 2019 | 03:03 PM
AJWinters's Avatar
AJWinters
Thank you so much. I forgot to mention this, but does this apply to 2017 model? Again, I greatly appreciate it.
Old Mar 21, 2019 | 03:28 PM
They are all the same since 2009.
Old Mar 21, 2019 | 03:29 PM
AJWinters's Avatar
AJWinters
Thank you so very much. You're a life saver!.
