Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2009 journey sxt misfire under load
Old Aug 30, 2020 | 02:33 PM
Jstlvnlif's Avatar
Jstlvnlif
Default 2009 journey sxt misfire under load
Journey bought with p0300 code. Multiple cylinder misfire. Mechanic replaced plugs, coils and injectors. Idles and can rev up in park and it does fine now. Put in drive or reverse and it starts with the multiple cylinder misfire and after test drive it wouldn’t go past 2,000 rpm and gave a p0016 camshaft and crankshaft position sensor bank 1 sensor a correlation code. Any ideas what I should do next?
Old Sep 13, 2020 | 06:20 PM
Gary Wiebe's Avatar
Gary Wiebe
it is possible that the crankshaft and camshaft positions sensors need to go through a relearn procedure. This however requires a dealer level scan tool.
Old Nov 30, 2020 | 08:32 PM
joemel's Avatar
joemel
Hi there, I also have the P0300 code on a 2010 2.4L Journey. Did you have any other work done or are you still receiving the code^ Thanks.
