dodge magnum makes noise
Old Apr 13, 2007 | 05:31 PM
adamec2004's Avatar
adamec2004
Default dodge magnum makes noise
hi i just got a used 05 dodge magnum qith 24k miles on it. the problem is when ever i turn the sterring wheel complete in either direction it makes a noise like a kind of groan.. the dealer service guy says i am putting pressure on the power steering pump but i think hes telling me whatever they can to not have to fix anything. can anyone help????
Old Apr 13, 2007 | 11:14 PM
darkrt's Avatar
darkrt
Default RE: dodge magnum makes noise
I hear a slight groan when I'm turned full tilt left or right. It only happens when backing slowly.
Old Apr 14, 2007 | 06:04 AM
TrippHemi's Avatar
TrippHemi
You can tell if it's the power steering by turning the wheel to left or right lock. If it makes the noise when the car is not moving, it's the steering and this is normal... at least for domestic cars. If it does it while you're moving, it's probably in the suspension somewhere... probably the front end.
Did you demonstrate the sound for the service tech? Doing that could help her/him/it get to the source. I used to have a Saab that would groan and thunk when the wheels were turned... especially when the car was cold. Tightening the suspension bolts helped for a while. However it was a systemic problem that eventually came back.
Old Apr 19, 2007 | 03:50 PM
Dave05RT's Avatar
Dave05RT
I think there is a TSB for a groan in power steering. They have to change one of the hard lines that has a orifice update. Check infotrax.com
