Oil light ?
Old Jun 6, 2007 | 10:31 AM
jmj's Avatar
jmj
Default Oil light ?
Oil light ?
I recently purchased an 06 SXT . The oil light comes on at idle, and disappears uppon accel. or cruising.
The oil was changed recently. Is there a oil change reset that I should do?
Any and all help would be appreciated.
Thanks
Old Jun 6, 2007 | 12:44 PM
darkrt's Avatar
darkrt
Default RE: Oil light ?
There is no reset. Check your oil level. If its ok,see your dealer.
Old Jun 6, 2007 | 02:39 PM
65standard's Avatar
65standard
check the oil level. the 3.5 engine takes 6 quarts. if the level is good, go to the dealer as soon as you can.
as darkrt said, there is no reset.
Old Jun 8, 2007 | 01:01 AM
jmj's Avatar
jmj
Thanks
Problem solved. Faulty oil pressure switch. Warranty item. Fixed
Old Jun 8, 2007 | 01:16 AM
65standard's Avatar
65standard
good deal. i'm glad it was so simple.
