WINDOW MOLDING
Old Jul 4, 2007 | 02:51 PM
WINNIPEG's Avatar
WINNIPEG
Default WINDOW MOLDING
HI NEW HERE. WOULD JUST LIKE TO KNOW WHAT TO DO TO INSTALL THE LOWER WINDOW MOLDINGS. BOUGHT THE DUB CHROME ONES. IS IT PRETTY STRAIGHT FORWARD OR SHOULD I TAKE IT TO THE DEALER. ANY INFO WOULD BE GREATLT APPRECIATED...
Old Jul 6, 2007 | 12:51 PM
LtlDad's Avatar
LtlDad
Default RE: WINDOW MOLDING
No need to take to dealer. Simply remove the door panel (pop pins, press in center to remove) and then remove the mirror from the inside of door (under door panel). One screw is visable on both the front and rear door, although other is under door panel.
NOTE: On rear, it is easier to drop the latch assembly to get to screw. 2 per sill and are TOREX.
