Exterior Trim
Old Jul 9, 2007 | 09:54 PM
Imsinin's Avatar
Imsinin
Default Exterior Trim
I have read that many of you removed the trim from the exterior of your Magnums. Is there any special trick to this? I am not sure if they just stick on using a 3m type adhesive or if they are attached another way. I just want to be sure I do it the correct way as to not damage the paint.
Thanks
Old Jul 11, 2007 | 06:47 PM
65standard's Avatar
65standard
Default RE: Exterior Trim
i used goo gone to soak the top of the molding and let it soften the glue. i then used a plastic bondo spreader to get behind the molding and cut the glue off the paint. i kept adding more and more goo gone as i continued to cut the glue with the bondo spreader. it worked perfectly with no glue or tape left on.
all the emblem and moldings on my car were glued one. only the front ram emblem is bolted on.
Old Jul 12, 2007 | 10:10 AM
Imsinin's Avatar
Imsinin
Thanks for the info!
Old Jul 12, 2007 | 05:05 PM
shiltz's Avatar
shiltz
Be carefull if you do the bondo spreader, tried that on mine for the first piece (little one on the front fender), scratched up the paint cause of the dirt, sand, etc that gets trapped behind there. I found that a length of fishing line and two dowels, sticks or anything else you can tie it to for handles works great though.
