05 MAGNUM
Old Jul 25, 2007 | 02:00 PM
rh3822's Avatar
rh3822
Default 05 MAGNUM
can anyone tell me how to program my key.i replaced the battery and need to reprogram it.thank you in advance
Old Jul 25, 2007 | 08:54 PM
MySRT's Avatar
MySRT
Default RE: 05 MAGNUM
You will need 2 keys and the instructions are in the owners manual. If you only have one good key you will need to have the dealer set up the second key.
Old Jul 26, 2007 | 07:47 AM
Strykker's Avatar
Strykker
Here you go.
[ul][*]1. Insert one of two programmed keys and turn ignition switch to on.
2. After ignition has been set to On for over 3 seconds but not more than 15 seconds turn the ignition back to Off.
3. With in 15 seconds insert the second key and turn the ignition switch to on.
4. About 10 seconds later the security indicator in the instrument cluster will start flashing.
5. With in 60 seconds replace the second key in the ignition with the new key. Turn the ignition switch to On using the new key.
6. After about 10 seconds the security indicator will stay on for about 3 seconds and then turn off to indicate that the key was successfully programmed. Turn the ignition to Off and you can now use the new key with the vehicle. [/ul]
You can program up to 8 keys to a vehicle.
