flex-fuel question
Old Nov 4, 2004 | 10:32 PM
DakotaRT2K's Avatar
DakotaRT2K
Default flex-fuel question
A buddy at work has become pretty fascinated with the magnum since i've ordered mine and thinks he might want one. but he is on this e85 fuel kick, he bought a caravan a couple years ago that ran on it, and wants to know if any/all of the magnum engines are available with that option. I didn't know and couldn't find anything on the web that said definitivly either way. so if any one knows...
-Ethan
Old Nov 5, 2004 | 02:33 AM
dodgemech's Avatar
dodgemech
Default RE: flex-fuel question
Nope
Old Sep 3, 2005 | 08:44 PM
cmdycrzr's Avatar
cmdycrzr
Isn't the same 2.7L engine found in the Sebring that same as the Magnum? If it is, then according to the following link, it should be E85 fuel compatible shouldn't it? Or are there two variations of the 2.7L manufactured?
In light the BS fuel crisis, I think if DC was smart they would start building their engines so it can use both regular gas or E85 fuels.
http://www.eere.energy.gov/afdc/progs/veh_specs.cgi?365
Old Sep 4, 2005 | 02:20 PM
a76marine's Avatar
a76marine
If you go to http://www.e85fuel.com you will see under the "Frequently Asked Questions" link that vehicles approved for e85 need to have special fuel filters and fuel line to deal with the extra corrosive ethanol.
Unfortunately the Mags are not yet ready.
Old Sep 4, 2005 | 11:26 PM
cmdycrzr's Avatar
cmdycrzr
76Marine,
First of all, thank you for what you are doing over in the Middle East. I don't know if there is anything else I can say to express my gratitude to you and your fellow Marines. The media certainly does not do you guys/gals justice as far as I am concerned.
I read up on the E85 issue and it does seem like this country needs to move in that sort of direction to back off the need of imported oil. Too bad the oil companies are probably straggling anyone from making this become a reality.
Semper Fi, God Speed and hurry home to your Magnum!
Old May 2, 2006 | 07:33 PM
JeyDizzle's Avatar
JeyDizzle
I know this topic is pretty old, but I wanted to see if anyone else had any info on this. From what I understand all modern US vehicles are OK to run Ethanol (E85) from a mechanical perspective, but may or may not be set up to automatically detect the fuel mixture. I recently found the following link:
http://xcelplus.com/e85/Converter%20Store.htm
However, I'm not sure what kind of injectors the Magnum uses. Can anyone help with this? I'm very interested in running my Mag on E85 (since it burns cleaner and has a higher octane, and is considerably cheaper now), but I can't find any info on the subject for my hotrod.
Thanks!
JeyDizzle
