Fuel saver mode?
Old Nov 28, 2007 | 12:43 AM
Magmania's Avatar
Magmania
Default RE: Fuel saver mode?
ORIGINAL: PogueMahone
You were way more kind than I would have been about the MDS operation causing RPM's to drop. (LOL) Moron's should not be allowed to drive and own cars.
Very nice Pogue.
You only have 4 posts under your belt and one of them is an attempted insult to a fellow member.
Glad to have you aboard. <--- that's sarcasm just incase your not gettin' it!
Old Nov 28, 2007 | 11:56 PM
Al Briggs's Avatar
Al Briggs
I notice a slight change in the exhaust "sound." I have a modified exhaust though. It may not be apparent in stock exhaust.
I have to wonder though: Why does it matter? If you step on the gas, the MDS goes off and your V-8 Hemi power is there to use.
Keeping a steady speed on the interstate, at 70 mph, I enjoyed mid-to-high 20's in MPG.
Old Nov 29, 2007 | 12:05 AM
Al Briggs's Avatar
Al Briggs
Moron's: This implies a possessive. So, you were referring to someone named Moron?
Otherwise, the word," Morons" would be used, without the apostrophe, indicating that you are insulting a fellow memberof this forum. There's no need for that.
Old Dec 12, 2007 | 10:08 AM
majorchaos's Avatar
majorchaos
ORIGINAL: Magmania
Not that this helps (^^ they pretty much covered it all ^^)
I read that the 08's come with an MDS indicator light. It's about time.
If they do, I haven't found it. *goes off to RTFM... again*
Only place I've found, so far, is on the EVIC, there is a screen for "Average Gas Milage". When the MDS is active, it says "Fuel Saver Mode", and doesn't when the MDS is not active.
I have a 2008 R/T.
I wonder if there are different versions of the EVIC too?
Old Dec 21, 2007 | 08:36 PM
Pokemasterflex's Avatar
Pokemasterflex
when does the fuel saver mode kick in?
Old Dec 25, 2007 | 07:58 PM
Magmania's Avatar
Magmania
When ever the conditions are right for it.
There is no 1 point that can be a pinpoint.
Probably has to do with throttle demand, road conditions (i.e. inclined or level), things of that nature.
I have felt it kick in and work when doing 25 mph through my neighborhood and also when cruising at 75 mph on the freeway.
