GEAR RATIO
Old Nov 18, 2007 | 11:39 AM
glhsmagnum's Avatar
glhsmagnum
Default GEAR RATIO
IS THERE ANY AFTER MARKET CO MAKING DIFFRENT GEAR RATIO FOR 06 MAGNUMS ???
Old Nov 18, 2007 | 06:29 PM
65standard's Avatar
65standard
Default RE: GEAR RATIO
not yet.
Old Nov 19, 2007 | 05:24 AM
HankL's Avatar
HankL
AMG in Germany can supply both differential gears
and individual gearsets for the automatic transmission
but the prices are 'Mercedes High'
If you can find some wrecked Mercedes vehicles in junk yards
if might be possible to swap parts
since there are several versions of the trans with interchangeable gearset.
archived info on auto trans in Magnum:
Mercedes-Benz transmissions used in:
ML230
ML320
ML430
ML55
ML270CDI
ML270CDI
5 sp manual
5 sp auto
5 sp auto
5 sp auto
5 sp auto
6 sp manual
transmission type designation
GL76/29B-5
W5A330
W5A 580
W5A 580
W5A 580
NSG 370 *
max. torque input
202 lb / ft
275 Nm
242 lb / ft
330 Nm
426 lb / ft
580 Nm
426 lb / ft
580 Nm
426 lb / ft
580 Nm
272 lb / ft
370 Nm
1st
3.856 :1
3.951 :1
3.595 :1
3.595 :1
3.595 :1
5.014 :1
2nd
2.183 :1
2.423 :1
2.186 :1
2.186 :1
2.186 :1
2.831 :1
3rd
1.376 :1
1.486 :1
1.405 :1
1.405 :1
1.405 :1
1.789 :1
4th
1.000 :1
1.000 :1
1.000 :1
1.000 :1
1.000 :1
1.256 :1
5th
0.799 :1
0.833 :1
0.831 :1
0.831 :1
0.831 :1
1.000 :1
6th
0.828 :1
reverse
4.218 :1
3.147 :1
3.167 :1
3.167 :1
3.167 :1
4.569 :1
torque converter ratio
1.85 :1
1.80 :1
1.80 :1
1.80 :1
weight
31.8 kg
76 kg
80 kg
80 kg
80 kg
40.5 kg
previous versions
W 5A 300
W5A 400
