Crankshaft position sensor
Old Dec 2, 2007 | 01:03 PM
starkrud's Avatar
starkrud
Default Crankshaft position sensor
Help, I need to locate the crankshaft position sensor. 2005 Dodge magnum R/T, 5.7 L Hemi.
Old Dec 2, 2007 | 02:18 PM
65standard's Avatar
65standard
Default RE: Crankshaft position sensor
a little hard to get at. it is on the passenger side of the block, all the way in the rear.
what do you want to do with it?
Old Dec 2, 2007 | 04:38 PM
starkrud's Avatar
starkrud
Thanks, check engine light, obdll says crankshaft position sensor failure
Old Nov 5, 2020 | 02:17 PM
Jayson Paris's Avatar
Jayson Paris
trying to acquire some info, my dad recently bought a 2005 Magnum, it's randomly stalling while idling then shuttering when sometimes trying to (lighty) accelerate. I was wondering what symptoms you had before messing w/ crankshaft position sensor and if you solved ur prob., or if you found the cause of the CPS failure code? I am new to this forum so if anyone could help me with this issue I thank you in advance. Also regardless I will follow up on this thread n report any info I find usefule. It seems like some are forgetting to return to this website after problem is solved. (SMH)
Old Nov 5, 2020 | 09:29 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
13yrs lol? Really?
