Snow Tire Information
Old Dec 10, 2007 | 10:18 PM
46FD04's Avatar
46FD04
Default Snow Tire Information
I have a 2007 Magnum SXT with 18" aluminum wheels, RWD. I've just installed winter tires and I thought I'd pass on some very important information.
1. A Magnum WITHOUT a Hemi motor and WITHOUT beefed up brakes can use 17" wheels for winter tires.
2. The correct tire size to use is 215 - 65R - 17.
3. You must use the correct steel rims, or the front tires WILL rub against the suspension. After market rims work great, as long as they are the correct ones (designed to fit Magnum, Charger, and 300).
4. And finally, the original lug nuts WILL NOT fit the steel rims, and a 2nd set of lug nuts will be required.
Quite a hassle to get winter tires installed, but after the ice/snow storm we had 2 weeks ago, it was necessary.
Old Jan 8, 2008 | 04:30 PM
JH Magnum's Avatar
JH Magnum
Default RE: Snow Tire Information
Hey 46FD04,
You didn't mention what kind of tires you put on.
I use Michelin Latitude X-ice on My SXT and they are FANTASTIC.
JH
Old Jan 9, 2008 | 06:06 PM
46FD04's Avatar
46FD04
Hi. Yes I did forget, and funny enough, I put the same tires on as you did.
They are EXCELLENT!
Old Jan 9, 2008 | 08:39 PM
65standard's Avatar
65standard
why not use stock 18" wheels?
Old Jan 10, 2008 | 04:57 PM
46FD04's Avatar
46FD04
I used 17" wheels for the snows because, 18" snow tires are hard to find AND very expensive.
Each 18" snow tire was over $100 more than 17" tires.
Old Jan 22, 2008 | 09:19 PM
davwall's Avatar
davwall
actually i was unable to find any true snow tires for my r/t 225 60 18. used good year assurance for all season...stay away from them!! horrible.... can someone offer a suggestion(s) for true snow's in that size?? all searches came up all seasons..living in toronto you tend to need them...since i can't put on 17 inch rims this is a problem
Old Jan 22, 2008 | 09:29 PM
65standard's Avatar
65standard
why can't you use 17" rims?
Old Jan 22, 2008 | 10:11 PM
davwall's Avatar
davwall
i thought i read on another post that due to brake size and hemi you can't put them on? can you put on the standard 17 inch steel rims on a r/t?
Old Jan 23, 2008 | 08:14 PM
65standard's Avatar
65standard
the factory 17" wheels fit just fine in the rear of the magnum r/t. they just won't fit the front.
Old Mar 22, 2008 | 07:11 PM
davwall's Avatar
davwall
i put on toyo g92 plus winter tires...absolutely great!!! use with traction control for best handling. not the quietest ride but smooth and ample snow grip!! proof in the latest toronto winter storm. highly recommended!!
