Blue Tooth
Old Dec 1, 2004 | 12:57 PM
mikewink's Avatar
mikewink
Default Blue Tooth
Has anyone had any luck with the Blue Tooth feature. I finally got a Blue tooth phone, followed the directions in the manual to find the phone (which worked) but when I go to use the phone it says "phone not found" Has anyone worked with this yet?
Old Dec 1, 2004 | 02:00 PM
Wicked96SS's Avatar
Wicked96SS
Default RE: Blue Tooth
I use Verizon and a Motorola V710... by default the bluetooth transmitter/reciever is turned off... for UCONNECT to work correctly you have to go into the settings and turn the bluetooth feature on all the time, drains the battery a bit, but not too bad, should have no problems if you charge every night. Before I found this setting, I would have to manually go to the bluetooth on or I would get the same error.
Mine has been working now for about 2 weeks, and I really like the feature.
Hope this helps!
Old Dec 1, 2004 | 10:00 PM
HemiMag's Avatar
HemiMag
I had my v600 before I got the Magnum....so I set it up as soon as I left the lot. I am in the habit of
turning on the bluetooth of my phone as soon as I get in the car. It is an awesome feature, happy to
have it.
Old Dec 2, 2004 | 02:35 AM
mikewink's Avatar
mikewink
Got it going - kind of. I have not been able to dial with voice commands but the car does recogize the phone when I dial the number through the phone and use the stereo as the head set. I also recognizes an incoming call. Thanks for your help.
Old Feb 1, 2005 | 10:01 PM
DakotaRT2K's Avatar
DakotaRT2K
I have a Nokia 3650 phone, and it is listed on the chrysler site as compatible. has anyone had any success with this phone and the uconnect feature. Thanks
Ethan
Old Feb 3, 2005 | 12:08 AM
elwolf's Avatar
elwolf
Check to see if phone's Bluetooth is set up in handsfree mode as apposed to headset mode. The U-Connect will only work if the phone is in handsfree profile.
