Vortech V3 Supercharger System - Installed!
Old May 21, 2008 | 02:46 AM
kevinpowertv's Avatar
kevinpowertv
Default Vortech V3 Supercharger System - Installed!
Hey guys,
Been a while since I've been on here. I told you I would be doing some serious mods on my Magnum, and I have!
Check out this supercharger system Vortech put on for me! I believe I'm the first magnum owner to have it! I'm going to run it on the dyno this week hopefully, so stay tuned for the performance numbers. Right off the bat, I can tell this thing has added at least 100+ hp.
Old May 22, 2008 | 06:32 PM
2005 Magnum R/T Hemi's Avatar
Default RE: Vortech V3 Supercharger System - Installed!
Kevinpowertv,
Wow! Looks nice! Be sure to post those Dyno results you are teasing us with...
What other Mods have you done in preperation for the Super Charger? Pistons for sure... I put a hole in Piston #6 with the Stock Set-up, so I am just guessing that you replaced the Cam, Pistons, had the Heads re-done, etc...
What Chip is being used for the Vortech Set-Up? What kind of Exhasut are you using? Be sure to read the Pedal Displacement when it is on the Dyno, that way you can get results at 25% Pedal, 50% Pedal, 75% Pedal and WFO...
Have fun!!!
Old May 24, 2008 | 07:10 PM
65standard's Avatar
65standard
nice. you should lose the engine cover and just go with some 6.1 style half covers.
just giving you some options here...
here are the carbon fiber covers i am using.
