Installed Photos- Wilwood RED Calipers
I just got the first set of the new TCE Performance Caliper Kit with the Wilwood 6 piston Calipers in RED installed by Todd at TCE Performance last night. Tod and I installed the calipers and new factory stock rotors modified by grooving and Zinc plating the rotors. The install is reasonabily easy took less than 2 hours wanted to share some photos.
Much improved pedal and solid stops from 90 - 0 many times in a row, I think it is a substancial improvement, how much exactly I couldn't tell you but it felt like 15 - 20 feet better from 80 - 0 stops
TCE Performance sells the front kit in black or red with the 6 piston Wilwood brakes and stainless steel lines and mounting hardware and brakets from $1400 - $1600 rotor mods were a few dollars more and can be done locally if you want them done. Complete system with larger rotors etc is $2500 or so. Rear kit is still in development.
Trending Topics
The shot of red looks good, I think I'm going to just paint my rotors, and it looks like red is the way to go! Thanks for the pics, the car looks great. What size rims/tires do you have and are you on lowering springs or stock? Thanks
