Noise from under car
Old Aug 16, 2008 | 02:21 PM
intensedrive's Avatar
intensedrive
Default Noise from under car
I have a fairly new ( to me) 05 RT that seems to have this sound that moves from tire to tire as I go slowly through a parking lot or over a bump. I thought at first it may be the traction control since it seemed to be following the tires as they went over the bump, but I am not to sure now. I do not hear the noise any other time, and it does not sound like metal on metal, popping snapping, clanking, rubbing.. it sounds like a wobble from tire to tire. The car has not been lowered and it does not pull in any direction, actually it drives so smooth it floats, it just has this odd noise..
Any suggestions?
Old Aug 24, 2008 | 02:39 PM
POWERMAGNUM's Avatar
POWERMAGNUM
Junior Member
Sounds like you got worn out strut mounts
Old Sep 11, 2008 | 06:04 PM
intensedrive
So I found out the problem, I have two bad tie rods and bad bearings on one side.
