ESP BAS fault
Old Sep 30, 2008 | 02:51 PM
Slow R/T's Avatar
Slow R/T
Default ESP BAS fault
The ESP BAS fault light is lit.
There are no fault codes (DTC).
How can I trouble shoot this probelm?
Old Sep 30, 2008 | 08:13 PM
65standard's Avatar
65standard
try to reset the steering sensor by turning the wheel all the way to the left and then the right. drive it around making turns to see if the light goes out. if that doesn't work, you may need a new steering sensor. the dealer can tell for sure.
Old Oct 1, 2008 | 04:51 PM
eaglestorm's Avatar
eaglestorm
codes for that wont be stored in the pcm there in the esp module aftermarke scaners wont normaly pull those codes
