Check Engine Light
Old Oct 13, 2008 | 08:44 AM
jbarnes90's Avatar
jbarnes90
Default Check Engine Light
My Check engine light came on in my 05 magnum. I checked the code and it is u0101. Does anyone have any ideas on what the code is and how to fix it.
Old Oct 13, 2008 | 08:17 PM
65standard's Avatar
65standard
it means lost communication with the TCM (transmission control module). i would try clearing the code and see if it comes back first. it maybe just a glitch. you can also check the wire connection at the TCM and make sure it's secure. the TCM is a small box under the dash by the steering column. if someone was messing under there, they may have loosen the connection. finally, the TCM itself maybe failing. good luck
